Unit-scaling inserted database...
When I browse and insert a block that contains an MVBlock I get this message at the command prompt: "Unit-scaling inserted database...Specify insertion point or [Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:" What does the "Unit-scaling inserted database..." mean?
It means that the database (DWG) that the inserted block is coming from is a different unit than the one you are inserting it into. For example, one is "millimeters" and the other is "inches". It has to scale the incoming database by the correct amount so that it matches the current unit. Jim Awe Autodesk, Inc. "Chris Picklesimer" wrote in message news:408febf8_2@newsprd01... > When I browse and insert a block that contains an MVBlock I get this message > at the command prompt: > > "Unit-scaling inserted database...Specify insertion point or > [Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:" > > What does the "Unit-scaling inserted database..." mean? > > >
