AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Speed IFC export
4 REPLIES 4
hlammerts
780 Views, 4 Replies
Speed IFC export
Hi, we want to make some of our models available as IFC to pass it on to Revit and other software. A export of a relative simple model takes me about half an hour.  One single item takes 9(!) seconds. That is a lot! 259*9/60 is about half an hour.
What impovements in setting or modelling can be to give me a workable solution for bigger models? It is to slow to really work.
4 REPLIES 4
pendean
in reply to: hlammerts
Your content amount./complexity dictates the speed of the export, unless you are running AutoCADARCH on a very low end PC that is just slow in general use of the program.
hlammerts
in reply to: pendean
No, its not that
Seeing similar results for single-family model.
How did you get that output of the time it took to run?  I'd like to be able to capture that.
hlammerts
