Hello all,
We're working on AutoCAD Architecture 2023. When we open it we always have this palette open. We don't want to have this palette. What can we do so when we open AutoCAD this palette doesn't show automatically?
Thank
Solved by pendean. Go to Solution.
Close it not an option? Or is your workspace and profile loaded from an external startup someone created for you all?
Or close it then actively save that workspace using WSSAVE command. Repeat for every workspace and profile you might use. unless, as I noted above, someone is forcing you all with a reset at startup.
If you had something else in mind then please share your thoughts.
HTH
Close is an option but I was tired of closing it each time I open AutoCAD. WSSAVE solved it.
Thanks!!
