Create wall with door using .net.
cesar_mayorine362SG
cesar_mayorine362SG
Hello everyone,
Is it possible to create and insert a wall using .net API and add a door to it?
thanks in advance.
Gepaha
Yes, it is possible, although until today I have never had the need for it.
If you search the internet you will find examples which you can adapt to your needs.
The AutoCAD Architecture .NET API webcast has a basic example.
https://adndevblog.typepad.com/aec/2013/05/api-webcast-archive.html
cesar_mayorine362SG
The links on this page do not work properly!
César
Gepaha
See if you can download the file I attached.
cesar_mayorine362SG
Thank you!
