AutoCAD Architecture PropertySetDefinition using .net
cesar_mayorine362SG
cesar_mayorine362SG
I am looking for a way to export from a source drawing to another.
The PropertySetDefinition, in drawing 1 contains an updated PropertySetDefinition and this should be overwritten in the receiving drawing.
I try:
sourceDb.WblockCloneObjects(sourceIds, destDbMsId, mapping, DuplicateRecordCloning.Replace, false)
but
DuplicateRecordCloning.Replace dont work.
cesar_mayorine362SG
Hello everyone,
I have tried these codes, the problem is that they do not overwrite the User Extended  Parameters from AEC Space.
If I use WblockCloneObjects, it generates a copy of the Spaces Parameters with "(2)" it comes from the Source drawing,  but it does not overwrite the current one.
Best regards
César Mayorine.
Gepaha
I assume you are trying to import a Space Style! But, the idea is the same for importing PropertySetDefiniton.
What do you mean by User Extended Parameters from AEC Space?
I did a very simple test and it's working correctly with CloningHelper.
Are you using CloningHelper MergeType = DictionaryRecordMergeBehavior.Overwrite?
[CommandMethod("ImportSpaceStyleTest")]
 public void ImportSpaceStyleTest()
   try
      Database dbDestination =  HostApplicationServices.WorkingDatabase;
      string SourcePath = @"C:\temp\Spaces - Residential (Metric).dwg";
      Database dbSource = new Database(false, true);
      dbSource.ReadDwgFile(SourcePath,  System.IO.FileShare.Read, true, "");
      DictionarySpaceStyle dictSpaceStyle = new DictionarySpaceStyle(dbSource);
      //  get the list of style ids that you want to import.
      //  (1) if you want to import everything, use this:
      // the list of ids in the style dictionary.
      // ObjectIdCollection objCollectionsrc=dictStyle.Records;
      // (2) if you want to import a specific style, use this:
      // we assume you know the name of style you want to import.
      AcDb.ObjectIdCollection objCollectionsrc=new AcDb.ObjectIdCollection();
      objCollectionSrc.Add(dictSpaceStyle.GetAt("Bathroom_Large"));
      //  now use CloningHelper class to import styles.
      //  there are four options for merge type:
      //    Normal     = 0, // no overwrite
      //    Overwrite  = 1, // this is default.
      //    Unique     = 2, // rename it if the same name exists.
      //    Merge      = 3  // no overwrite + add overlapping as anonymous
      Autodesk.Aec.ApplicationServices.Utility.CloningHelper helpme = new Autodesk.Aec.ApplicationServices.Utility.CloningHelper();
      // helpme.MergeType = Autodesk.Aec.ApplicationServices.Utility.DictionaryRecordMergeBehavior.Normal;
      helpme.MergeType = Autodesk.Aec.ApplicationServices.Utility.DictionaryRecordMergeBehavior.Overwrite;
      // helpme.MergeType = Autodesk.Aec.ApplicationServices.Utility.DictionaryRecordMergeBehavior.Unique;
      // helpme.MergeType = Autodesk.Aec.ApplicationServices.Utility.DictionaryRecordMergeBehavior.Merge;
      helpme.Clone(dbSource, dbDestination, objCollectionSrc, dictSpaceStyle.RecordType, true);
   catch (System.Exception e)
   { Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(e.Message);
[CommandMethod("ImportPropertySetDefinitionTest")]
public void ImportPropertySetDefinitionTest()
  try
     string SourcePath = @"C:\temp\Schedule Tables (Metric).dwg";
     DictionaryPropertySetDefinitions dictPropSetDef = new DictionaryPropertySetDefinitions(dbSource);
     objCollectionSrc.Add(dictPropSetDef.GetAt("SpaceStyles"));
     helpme.Clone(dbSource, dbDestination, objCollectionSrc, dictPropSetDef.RecordType, true);
