Dimension ray
I want to share this new macro to dimension plans with aec dimension group
It made to speed up making of dimension chains for walls of cumbersome plans. it based on the construction lines that used like an location halper for dimension chaine.- tha is why it called dimensionRAY
1 It restriction is unuseble for xref planes( but I'm working at this problem)
2 It only horisontal and vertical dimension only
3 Vertical Area from the left ( aprox 2 m) can't properly attched with dimension it turns to horisontal .
4 macro unstable and raw a bit, it would be nice to help me some one to fix it.
5 The bigger plan the slower work of this macro...but it still faster and more apropriate to do dimension with this macro any way
Guide
after msgbox " select places for dimention lines and press escape or press enter twise " you need to create construction lines, but use only (click on it ) walls objects to referense it derection and then move construction line to any location of plan.It could be few lines as you wish
It would be nice to have this instrument as standart ACA tool but .(My wish list)
macro has no any specific references
Sub dimantionray() 'This macro automate attachment of horizontal and vertical dimension to plan view 'via xline like signe lines Dim sset1 As AcadSelectionSet Dim sset2 As AcadSelectionSet Dim sset3 As AcadSelectionSet Dim sset4 As AcadSelectionSet Dim wall As AecWall Dim xln As AcadXline Dim ent As AcadEntity Dim j As Integer Dim r As Integer Dim intPoints1 As Variant Dim stPoints(0 To 2) As Double Dim endPoints(0 To 2) As Double Dim pointhelpSt(0 To 2) As Double Dim pointhelpEd(0 To 2) As Double Dim pointWallJumpSt(0 To 2) As Double Dim pointWallJumpEd(0 To 2) As Double Dim lineObj1 As AcadLine Dim ArraY1() As Double On Error Resume Next Set sset1 = ThisDrawing.SelectionSets.Add("Selframe1") Set sset2 = ThisDrawing.SelectionSets.Add("SelAll1") Set sset3 = ThisDrawing.SelectionSets.Add("SelXline") Set sset4 = ThisDrawing.SelectionSets.Add("SellineForDim") 'select objects by frame MsgBox " Using selection frame , choice the plan area for attaching dimensions" sset2.Select acSelectionSetAll sset1.SelectOnScreen 'turn off all objects, and turn on only selected d = 0 count1 = sset2.Count - 1 For d = 0 To count1 sset2.Item(d).Visible = False Next j = 0 count1 = sset1.Count - 1 For j = 0 To count1 If sset1.Item(j).ObjectName = "AecDbWall" Or sset1.Item(j).ObjectName = "AecDbDimensionGroup" Then sset1.Item(j).Visible = True Else End If Next MsgBox " select places for dimention lines and press escape or press enter twise " 'applying dimantions line ThisDrawing.SendCommand "_AecConstructionLine" & vbCr Dim fCode(0 To 2) As Integer Dim fData(0 To 2) As Variant Dim groupCode As Variant, dataCode As Variant fCode(0) = 0: fData(0) = "XLINE" fCode(1) = 60: fData(1) = 0 fCode(2) = 67: fData(2) = 0 groupCode = fCode dataCode = fData sset3.Select acSelectionSetAll, , , groupCode, dataCode 'select all Xline 'check current x line for horisontality and verticality Dim vert As Double Dim horis As Double r = 0 count3 = sset3.Count - 1 For r = 0 To count3 IDob = sset3.Item(r).ObjectID Set xln = ThisDrawing.ObjectIdToObject(IDob) vert = xln.BasePoint(0) - xln.SecondPoint(0) 'it shold has zero result horis = xln.BasePoint(1) - xln.SecondPoint(1) 'it shold has zero result If vert = 0 Then 'MsgBox "vert" GoTo ok1 ElseIf horis = 0 Then 'MsgBox "horis" GoTo ok1 Else MsgBox "sloped skiped" xln.Delete GoTo onemore1 End If ok1: ' Searching for all visible walls and finding is it has intersection with current xline k = 0 For Each ent In ThisDrawing.ModelSpace If TypeOf ent Is AecWall And ent.Visible = True Then Set wall = ThisDrawing.ObjectIdToObject(ent.ObjectID) pointWallJumpSt(0) = wall.Location(0): pointWallJumpSt(1) = wall.Location(1): pointWallJumpSt(2) = wall.Location(2) pointWallJumpEd(0) = wall.Location(0): pointWallJumpEd(1) = wall.Location(1): pointWallJumpEd(2) = xln.BasePoint(2) 'move wall on z position of xline wall.Move pointWallJumpSt, pointWallJumpEd 'finde intersection of wall and xline intPoints1 = xln.IntersectWith(wall, acExtendNone) 'move wall back wall.Move pointWallJumpEd, pointWallJumpSt 'For "a SelectionSet Crossing" necessary two of furthest points that intersects the edge walls for current xline If vert = 0 And UBound(intPoints1) > 2 Then ' if it vertical wall and it interects with xlin then 'MsgBox "vert" ReDim Preserve ArraY1(0 To k) ArraY1(k) = intPoints1(1) 'gathering all intersecting Y value for compering k = k + 1 ElseIf horis = 0 And UBound(intPoints1) > 2 Then ' if it horisontal wall and it interects with xlin then ' MsgBox "hor" ReDim Preserve ArraY1(0 To k) ArraY1(k) = intPoints1(0) 'gathering all intersecting X value for compering k = k + 1 Else End If Else Set ent = Nothing End If Next Dim DimIsertPt As String Dim rotat As String 'Check is it at least 2 points 'MsgBox UBound(ArraY1) If UBound(ArraY1) >= 1 Then GoTo ok2 Else xln.Delete GoTo onemore1 End If ok2: If vert = 0 Then stPoints(0) = xln.BasePoint(0): stPoints(1) = WorksheetFunction.Min(ArraY1): stPoints(2) = 0 endPoints(0) = xln.BasePoint(0): endPoints(1) = WorksheetFunction.Max(ArraY1): endPoints(2) = 0 pointhelpSt(0) = Round(xln.BasePoint(0)): pointhelpSt(1) = Round(WorksheetFunction.Min(ArraY1)) - 1: pointhelpSt(2) = 0 pointhelpEd(0) = Round(xln.BasePoint(0)): pointhelpEd(1) = Round(WorksheetFunction.Max(ArraY1)) + 1: pointhelpEd(2) = 0 DimIsertPt = pointhelpSt(0) & "," & pointhelpEd(1) & "," & pointhelpSt(2) rotat = 270 ElseIf horis = 0 Then stPoints(0) = WorksheetFunction.Min(ArraY1): stPoints(1) = xln.BasePoint(1): stPoints(2) = 0 endPoints(0) = WorksheetFunction.Max(ArraY1): endPoints(1) = xln.BasePoint(1): endPoints(2) = 0 pointhelpSt(0) = Round(WorksheetFunction.Min(ArraY1)) - 1: pointhelpSt(1) = Round(xln.BasePoint(1)): pointhelpSt(2) = 0 pointhelpEd(0) = Round(WorksheetFunction.Max(ArraY1)) + 1: pointhelpEd(1) = Round(xln.BasePoint(1)): pointhelpEd(2) = 0 DimIsertPt = pointhelpEd(0) & "," & pointhelpEd(1) & "," & pointhelpEd(2) rotat = 180 'MsgBox UBound(ArraY1) & " * " & WorksheetFunction.Min(ArraY1) & " * " & WorksheetFunction.Max(ArraY1) 'MsgBox UBound(ArraY1) & " * " & pointhelpSt(1) & " * " & pointhelpEd(1) Else End If ' Set lineObj1 = ThisDrawing.ModelSpace.AddLine(stPoints, endPoints) xln.Delete sset4.Select acSelectionSetCrossing, stPoints, endPoints ' MsgBox sset4.Count sset4.Clear ThisDrawing.SendCommand "Select p " & vbCrLf ThisDrawing.SendCommand "DimAdd" & vbCr & "R" & vbCr & rotat & vbCr & DimIsertPt & vbCr onemore1: Next r For Each ent In ThisDrawing.ModelSpace ent.Visible = True Next ThisDrawing.SelectionSets("SellineForDim").Delete ThisDrawing.SelectionSets("Selframe1").Delete ThisDrawing.SelectionSets("SelAll1").Delete ThisDrawing.SelectionSets("SelXline").Delete MsgBox "Adding the dimensions to plan completed" End Sub
