Dimension ray
Dimension ray
brian_adams
Message 1 of 1
Dimension ray
brian_adams
I want to share this new macro to dimension plans with aec dimension group
It made to speed up making of dimension chains for walls of cumbersome plans. it based on the construction lines that used like an location halper for dimension chaine.- tha is why it called dimensionRAY
1 It restriction is unuseble for xref planes( but I'm working at this problem)
2 It only horisontal and vertical dimension only
3 Vertical Area from the left ( aprox 2 m) can't properly attched with dimension it turns to horisontal .
4 macro unstable and raw a bit, it would be nice to help me some one to fix it.
5 The bigger plan the slower work of this macro...but it still faster and more apropriate to do dimension with this macro any way
Guide
after msgbox " select places for dimention lines and press escape or press enter twise " you need to create construction lines, but use only (click on it ) walls objects to referense it derection and then move construction line to any location of plan.It could be few lines as you wish
It would be nice to have this instrument as standart ACA tool but .(My wish list)
construct line.JPGmacro has no any specific references
Sub dimantionray()
'This macro automate attachment of  horizontal and vertical dimension to plan view
'via xline like signe lines
 Dim sset1 As AcadSelectionSet
 Dim sset2 As AcadSelectionSet
 Dim sset3 As AcadSelectionSet
 Dim sset4 As AcadSelectionSet
 Dim wall As AecWall
 Dim xln As AcadXline
 Dim ent As AcadEntity
 Dim j As Integer
 Dim r As Integer
 Dim intPoints1 As Variant
 Dim stPoints(0 To 2) As Double
 Dim endPoints(0 To 2) As Double
 Dim pointhelpSt(0 To 2) As Double
 Dim pointhelpEd(0 To 2) As Double
 Dim pointWallJumpSt(0 To 2) As Double
 Dim pointWallJumpEd(0 To 2) As Double
 Dim lineObj1 As AcadLine
 Dim ArraY1() As Double
  On Error Resume Next
  Set sset1 = ThisDrawing.SelectionSets.Add("Selframe1")
  Set sset2 = ThisDrawing.SelectionSets.Add("SelAll1")
  Set sset3 = ThisDrawing.SelectionSets.Add("SelXline")
  Set sset4 = ThisDrawing.SelectionSets.Add("SellineForDim")
'select objects by frame
MsgBox " Using selection frame , choice the plan area for attaching  dimensions"
  sset2.Select acSelectionSetAll
  sset1.SelectOnScreen
'turn off all objects, and turn on only selected
    d = 0
   count1 = sset2.Count - 1
   For d = 0 To count1
   sset2.Item(d).Visible = False
   Next
    j = 0
   count1 = sset1.Count - 1
   For j = 0 To count1
   If sset1.Item(j).ObjectName = "AecDbWall" Or sset1.Item(j).ObjectName = "AecDbDimensionGroup" Then
      sset1.Item(j).Visible = True
   Else
   End If
   Next
   MsgBox " select places for dimention lines and press escape or press enter twise "
'applying dimantions line
  ThisDrawing.SendCommand "_AecConstructionLine" & vbCr
   Dim fCode(0 To 2) As Integer
   Dim fData(0 To 2) As Variant
   Dim groupCode As Variant, dataCode As Variant
   fCode(0) = 0: fData(0) = "XLINE"
   fCode(1) = 60: fData(1) = 0
   fCode(2) = 67: fData(2) = 0
   groupCode = fCode
   dataCode = fData
   sset3.Select acSelectionSetAll, , , groupCode, dataCode  'select all Xline
   'check current x line  for horisontality and verticality
  Dim vert As Double
  Dim horis As Double
   r = 0
   count3 = sset3.Count - 1
   For r = 0 To count3
     IDob = sset3.Item(r).ObjectID
     Set xln = ThisDrawing.ObjectIdToObject(IDob)
     vert = xln.BasePoint(0) - xln.SecondPoint(0) 'it shold has zero result
     horis = xln.BasePoint(1) - xln.SecondPoint(1) 'it shold has zero result
     If vert = 0 Then
        'MsgBox "vert"
        GoTo ok1
     ElseIf horis = 0 Then
        'MsgBox "horis"
        GoTo ok1
     Else
        MsgBox "sloped skiped"
        xln.Delete
     GoTo onemore1
     End If
ok1:
 ' Searching for all visible walls and finding is it has intersection with current xline
     k = 0
     For Each ent In ThisDrawing.ModelSpace
       If TypeOf ent Is AecWall And ent.Visible = True Then
         Set wall = ThisDrawing.ObjectIdToObject(ent.ObjectID)
         pointWallJumpSt(0) = wall.Location(0): pointWallJumpSt(1) = wall.Location(1): pointWallJumpSt(2) = wall.Location(2)
         pointWallJumpEd(0) = wall.Location(0): pointWallJumpEd(1) = wall.Location(1): pointWallJumpEd(2) = xln.BasePoint(2)
         'move wall on z position of xline
         wall.Move pointWallJumpSt, pointWallJumpEd
         'finde intersection of wall and xline
         intPoints1 = xln.IntersectWith(wall, acExtendNone)
         'move wall back
         wall.Move pointWallJumpEd, pointWallJumpSt
         'For "a SelectionSet Crossing" necessary two of furthest points that intersects the edge walls for current xline
          If vert = 0 And UBound(intPoints1) > 2 Then ' if it vertical wall and it interects with xlin then
            'MsgBox "vert"
             ReDim Preserve ArraY1(0 To k)
             ArraY1(k) = intPoints1(1) 'gathering all intersecting Y value for compering
             k = k + 1
          ElseIf horis = 0 And UBound(intPoints1) > 2 Then ' if it horisontal wall and it interects with xlin then
           ' MsgBox "hor"
             ArraY1(k) = intPoints1(0) 'gathering all intersecting X value for compering
             k = k + 1
          Else
          End If
       Else
          Set ent = Nothing
       End If
     Next
     Dim DimIsertPt As String
     Dim rotat As String
     'Check is it at least 2 points
     'MsgBox UBound(ArraY1)
     If UBound(ArraY1) >= 1 Then
     GoTo ok2
     Else
     xln.Delete
     GoTo onemore1
     End If
ok2:
     If vert = 0 Then
        stPoints(0) = xln.BasePoint(0): stPoints(1) = WorksheetFunction.Min(ArraY1): stPoints(2) = 0
        endPoints(0) = xln.BasePoint(0): endPoints(1) = WorksheetFunction.Max(ArraY1): endPoints(2) = 0
        pointhelpSt(0) = Round(xln.BasePoint(0)): pointhelpSt(1) = Round(WorksheetFunction.Min(ArraY1)) - 1: pointhelpSt(2) = 0
        pointhelpEd(0) = Round(xln.BasePoint(0)): pointhelpEd(1) = Round(WorksheetFunction.Max(ArraY1)) + 1: pointhelpEd(2) = 0
        DimIsertPt = pointhelpSt(0) & "," & pointhelpEd(1) & "," & pointhelpSt(2)
        rotat = 270
        stPoints(0) = WorksheetFunction.Min(ArraY1): stPoints(1) = xln.BasePoint(1): stPoints(2) = 0
        endPoints(0) = WorksheetFunction.Max(ArraY1): endPoints(1) = xln.BasePoint(1): endPoints(2) = 0
        pointhelpSt(0) = Round(WorksheetFunction.Min(ArraY1)) - 1: pointhelpSt(1) = Round(xln.BasePoint(1)): pointhelpSt(2) = 0
        pointhelpEd(0) = Round(WorksheetFunction.Max(ArraY1)) + 1: pointhelpEd(1) = Round(xln.BasePoint(1)): pointhelpEd(2) = 0
        DimIsertPt = pointhelpEd(0) & "," & pointhelpEd(1) & "," & pointhelpEd(2)
        rotat = 180
     'MsgBox UBound(ArraY1) & " * " & WorksheetFunction.Min(ArraY1) & " * " & WorksheetFunction.Max(ArraY1)
     'MsgBox UBound(ArraY1) & " * " & pointhelpSt(1) & " * " & pointhelpEd(1)
      Else
      End If
      ' Set lineObj1 = ThisDrawing.ModelSpace.AddLine(stPoints, endPoints)
       xln.Delete
       sset4.Select acSelectionSetCrossing, stPoints, endPoints
      ' MsgBox sset4.Count
       sset4.Clear
       ThisDrawing.SendCommand "Select p " & vbCrLf
       ThisDrawing.SendCommand "DimAdd" & vbCr & "R" & vbCr & rotat & vbCr & DimIsertPt & vbCr
onemore1:
   Next r
  ent.Visible = True
  Next
ThisDrawing.SelectionSets("SellineForDim").Delete
ThisDrawing.SelectionSets("Selframe1").Delete
ThisDrawing.SelectionSets("SelAll1").Delete
ThisDrawing.SelectionSets("SelXline").Delete
MsgBox "Adding the dimensions to plan completed"
End Sub
Replies (0)
