Create Wall from Space Boundary
mabanto-DLR
mabanto-DLR
The Space and Wall tools are great for concept design and space planning! I generally start with Spaces first. Then l trace the Space Boundaries with Walls. The walls are Center justified. Would it be possible to generate Walls from Space Boundaries? Something similar when you right click on the Walls tool in the Tool Palette, and select "Apply Tool Properties to Linework". But instead of linework, it can pick a Space Boundary.
Ed__Jobe
First, what you call Space Boundaries are not such. It's just like a polyline. You have drawn non-associative spaces. Space boundaries are are walls, etc, that bound an associative space. See this help topic to make a space associative. This method requires you to place walls around the space first. You could program a solution to select a space and then place walls around it, but it would get difficult if there are other spaces next to the one you select. Will the walls also be a boundary for those spaces? Of course, you need to first learn to program.
Ed
How to post your code.
R_Tweed
It is possible to generate walls from space boundaries in a couple of steps. I'm not a programmer, so the best I could offer would be the attached 2026 action recording which seems to work ok for me and mimics the steps below.
1. SpaceCreatePline command, select spaces. This will create plines at space edges on the current layer, preferably a layer other than the space layer. .
2. layiso to Isolate the plines layer.
3. overkill to remove overlapping and join adjacent linework,
4. aecwallconvert to convert the remaining linework to walls.
