Contour do not display
info
info
I am using ACA 2023 and losing the contour lines neither my surveyor, nor I can figure out the resolution? Is there add-on needed.
pendean
Community Legend
Community Legend
Are you both using AutoCAD variant software?
Did you both remember to turn on PROXYGRAPHICS and PROXYSHOW variables, saving the file(s), before exchanging that file(s)?
And do you need to also install the Civil3D object Enabler for ACA2023
OR... they can "export to autocad" and send you a dumbed down file for plain AutoCAD/ARCH use too.
David_W_Koch
Do you have the Civil 3D Object Enabler installed?  If not, the surveyor will need to save the file from Civil 3D with  PROXYGRAPHICS turned on.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
info
When you say "variant software" what does that mean? I will find the plug-in and coordinate with my Civil Consultant making sure we are in sync.
pendean
Community Legend
Community Legend
@info Variant, as in AutoCAD Architecture/MEP/Mechanical/C3D/Plant3D/Map3D... This forum is for (and responses will come from) plain AutoCAD users predominantly.
The C3D OE is universal for all AutoCAD variants if you get the correct year-matching version as I noted in my first reply to you with the screenshot from the Autodesk Account Page where you'd get it.
HTH
info
Got it, thank you. The plug-in was the trick.
