- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
1. I have a student licenced AutoCAD Architecture 2020 product. I'm new here, so far I've been able to find solutions for everything. And my skills need to be polished.
2. I converted walls and roof into 3D solid along with doors and a window. One wall is one 3d solid object now and the doors in it are the second 3d solid object now. However, when I move the doors (same thing with windows) and select clean command from solidedit it does not remove the vertices from 3d solid object "doors" in the wall.
3. The solution for deleting vertices would be as on AutoCAD official tutorial - to go to a home tab and go to a selection panel and select vertex. However, I've checked everything showing and on the home tab I do not have a selection panel. I' ve tried to search for a vertex both in the tabs and panels, but haven't found it. I also tried to run vertex as a command by typing it in, there isn't vertex command.
4. If I do not resolve the solidedit clean command, and if I don't find selection panel, how can I remove vertices without having to draw again or converting it to walls/roofs/etc...?
https://forums.autodesk.com/t5/autocad-forum/solid-editing-clean-not-working/m-p/7283225#M892311
This solution does not work.
I attached a screenshot for you to see,
