AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Autodesk Autocad Architecture Block Layers
1 REPLY 1
311 Views, 1 Reply
So I have searched online and through the forum and can't find the answer. Maybe im not using the correct keywords, but here it goes.
I have 2016 Autodesk Autocad Architecture.  I have created some basic blocks we use in our office ex. specialized sink.  This was drawn on the 0 layer and created in it's own drawing with a few other blocks.  This block has been placed into a palette for easy access to multiple users.  Now, when I place this block into another drawing, it inserts as the 0 layer.  My goal is to select say A-PLUMBING layer in the second drawing, and grab the block from the palette and to be inserted using the A-PLUMBING layer.  This could also be A-NEW-PLUMBING or A-EXISTING-PLUMBING layers.
Is there a way to have the block instert as the CURRENT selected layer instead of the layer the block was created on?
Thank you.
1 REPLY 1
Laks-Autodesk
This should be possible by choosing to use current layer in the tool properties. Right-click the block tool on the tool palette and choose Properties. In the tool properties, under General, select 'use current' as the value for Layer.
Lakshminarasimhan Seshadri
