We can blame this on my old, tired eyes, but I cannot see a difference between the two example wall graphics in your image.
The Shrink Wrap component can be on a separate layer from the Wall object and individual Component layers, if you want. You cannot put individual segments of the Shrink Wrap component on different layers, however. So if you have a Wall with GWB on one side of a Metal Stud, you cannot have the Shrink Wrap line that is on the outside face of the GWB on a different layer than the Shrink Wrap line on the outside face of the Metal Stud.
You can turn off the Shrink Wrap component, and put the outlines of each component in the Wall on unique layers, if you are willing to edit the out-of-the-box Display Settings to achieve that goal. But, like the Shrink Wrap component, you cannot put different segments of a component's outline on different layers. So, using the same GWB on one side of a Metal Stud Wall from the previous example, you cannot put the line on the outside face of the GWB on a different layer from the line on the inside face.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
