select objects with same color
Renee_Ve
Renee_Ve
I have imported a pdf, entire drawing in one layer,
and now I want to select the information,  multitext and polyline, that has color 127,127,127.
How do I manage to select this information in autocad architecture 2020?
thanks
Renee_Ve
Found the solution, it is Qselect command, and not quickselect command which doesn't work
rwrightWMDSY
Open the layer manager, double click on "color" at the top.  Layers will be sorted by color and you can pick what you want.
