Viewport in AutoCAD Architecture not matching printed PDF
BBP-Arch
BBP-Arch
ACA 2016
Got a weird thing w/ viewports. The viewport on the sheet and the printed PDF are not the same...it's as if the viewport has moved in the print. Take a look at the attached screenshot of the sheet in ACAD and the resulting PDF. They're off. We wind up having to stretch the viewport as a guess to where it will print to make it line up correctly. It doesn't happen all the time, but it's happened a few times recently on different jobs.
Anyone know what causes this?
@BBP-Arch for clarity Tiana.D edited the original subject: Viewport Anomaly
brian_adams
Simular problem was with my file. It was some thing wrong with file. Try to copy content of file to the new one with standart auocad template- model
BBP-Arch
Thanks. I'll try that.
Kevin.Palmer
Autodesk Support
Autodesk Support
Hi @BBP-Arch,
I'm just checking in to see if you need more help with this. Did the suggestion that @brian_adams provided work for you?
If not, would you be able to upload the file? We'd be happy to take a look at it for you. There are also some helpful plotting tips in this article about Exporting PDFs.
I hope this helps!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
dbroad
Difficult to diagnose without the DWG file.
Architect, Registered NC, VA, SC, & GA.
Kevin.Palmer
Autodesk Support
Autodesk Support
Hi @BBP-Arch,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
