Upgrade to 2022 or 2021 ACA?
dbroad
Mentor Mentor
dbroad
The real question here is, after almost a year, is the product significantly better than 2021?  I've read the product improvements link from Dean.  Has there been a fix for not being able to edit anonymous detailing blocks?  I really like the detail component manager.  Which version 2021 or 2022 is better in the short term (1-2 years)?
Architect, Registered NC, VA, SC, & GA.
pendean
Community Legend
Community Legend
Download/install ACA2022, then install the latest updates, and test/find out for yourself if it is worth it or not with your own files: no damage to your DWG files will occur, this would be a safe test as long as you are not stuck using ACA2017 now.
Then decide if you need to stick with ACA2021 for whatever reason you discover.
