Make changes to mirrored object independent from original
e1128951
e1128951
Community Visitor
Community Visitor
Hi there,
I am new to autocad and i have no idea how to make changes to the mirrored Block without affecting the Block that the mirrored version is made of. I am trying to change the color of a door, but whenever i try to do that in the block editor, it automaticaly changes the original one as well.
Can someone please tell me what I am doing wrong?
thanks in advance!
dbroad
You can't but you can use bedit to save the block as a similar block.  You should also look into using dynamic blocks.  Why are you posting in the AutoCAD Architecture forum.  If you are using ACA, use AECdoors instead.
Architect, Registered NC, VA, SC, & GA.
