AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Units and Drawing Setup
6 REPLIES 6
jdcho
5252 Views, 6 Replies
Is there a command that has the Drawing Setup dialogue box to come up when you type in units? On some machines, when you type in units, the drawing setup comes up with the units, scale, layering and display tabs. On other machines, you only get the units tab, and it doesn't say drawing setup on top.
Thanks in advance.
6 REPLIES 6
in reply to: jdcho
DDUNITS ?
I think UNITS just brings up the autocad only box
wrote in message news:6364853@discussion.autodesk.com...
top.
Thanks in advance.
jdcho
in reply to: jdcho
Yeah, I tried that command. But for some reason, both commands (ddunits and units) pulls up the autocad units only (the dialogue box without any of the tabs).
in reply to: jdcho
Is this plain AutoCAD or ACA?
jdcho
in reply to: jdcho
autocad architecture 2010 ...
in reply to: jdcho
UN should bring up the four tab, drawing setup dialog if you are in ACA 2010.
Make sure you haven't got a regular AutoCAD profile set current. hmmm. actually I just set a regular AutoCAD profile current in my ACA2010 and UN still brings up the full meal deal drawing setup dialog with Units, Scale, etc.
in reply to: jdcho
Did you ever figure this out? I'm using 2013 and Civil 3D 2016 but I'm thinking it would be the same thing. I've got the dialog box before but I can't remember how.
