Opening Shape Error
Opening Shape Error
I want a smooth curve line.
ctrl+C in old dwg and ctrl + V in new dwg file, sometime Then again, gwaenchya.
But after working, again error.
opening Shape-01.jpgopening Shape-02.jpgopening Shape-03.jpgopening Shape-04.jpg
David_W_Koch
AEC objects, such as Walls, will not display true curves, only faceted approximations of curves.  This is due to performance of the model.  As your image indicates, FACETDEV (Facet Deviation) and FACETMAX (Facet Maximum) are used to control the faceting.
  • Setting a smaller value for FACETDEV will increase the number of facets; it represents the maximum allowable distance from the midpoint of any one facet perpendicular to the true curve.
  • FACETMAX sets a maximum number of facets on one curve, which can be useful if you have curves of greatly varying size.  Smaller curves, with tighter radii, will want FACETDEV to be a fairly small number; to avoid a huge performance hit, FACETMAX allows you to set an upper limit to the number of facets on the large curves (overriding the FACETDEV setting).
That said, the odd treatment of your opening at the curves appears to be related to the Opening Endcap assigned to the Wall Style for Openings.  If I remove that, the holes in the wall disappear, and all of the components appear to curve nicely.  Unfortunately, I do not have time at the moment to examine that Wall Opening Endcap Style and the associated Wall Endcap Styles, to see if there is some adjustment that could be made to avoid the issue.  Decreasing FACETDEV and increasing FACETMAX make the anomalies at the curve worse, and add some to the other curves as well.  I would start troubleshooting this by checking out those endcaps and verifying there are no issues with them.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
