- Mute
- Permalink
- Report
I've created a floor plan bunch of items with (unknowingly) the transparency setting set to 50 on the properties pallete and I need to remove it however selected aec objects the prop pallete does not display any transparency option.
I've corrected the text which does show it but not for walls, windows, doors etc.
Is there a place this setting should show up so it can be manually changed?
Rather dumb that it applies but doesn't then show as a setting that can be edited later.
(No the transparency was not applied at a style level).
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
