AutoCAD Architecture 2018 crashes without warning when accessing file explorer
When AutoCAD Architecture tries to access file explorer (to open or save as) in Windows 10 it immediately crashes without any error dialog box or warning. Tried a repair and reinstall, removed every program/update added to the system around time this started happening and disabled all startup programs (though none are new or have caused problems in the past). Even reinstalled most current video driver since in the past that is usual suspect. Program works fine if it is launched from double clicking a DWG file until ACAD tries to access file explorer (like to Save As or open new file)
David_W_Koch
Are the latest updates installed?  For AutoCAD Architecture 2018, that would be both the AutoCAD 2018.1.2 update and the AutoCAD Architecture 2018.0.3 update.  Your About dialog should look like this:
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
I'm at 8.0.44.0 built on 0.154.0.0 so I'll try to update. Thanks for the suggestion.
