Transparency of multi-view blocks reference in pdf
staler.pc
staler.pc
Hi!
I created multi-view blocks reference with some transparency.
Why is the result difference in created pdf file and view realm of autocad?
The problem file is attached.
leothebuilder
I have not checked your attached file but one possibility occurs to me......in the plot dialog box did you check the box for "plot transparency"?
staler.pc
No, it is turned on if I right understand. If it had turned off you did not see any transparent objects on my screenshots.
