Some Tabs are missing from tool palettes
Beka_Tchigladze
Advisor Advisor
Beka_Tchigladze
Hello there are missing several tabs from tool palettes and how to turn it on ? talking about wall door window and so on
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
David_W_Koch
What AutoCAD Profile do you have set current?  Perhaps those are the only palettes available in that profile.  What you show in your image looks like the out-of-the-box AutoCAD Architecture (Global) profile is current.  Those are all the palettes that profile has, initially.
Did you install content other than the Global content?  If so, I would expect that you have other Profiles related to that content, and if you set one of those current, you would have tool palettes related to that content.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
scott323YW
Community Visitor
Community Visitor
David,
how do you install or find other content than just the global content? I'm trying to follow setup tutorials, but it does not discuss different content setups or installs.
David_W_Koch
@scott323YW
How did you install the software?  If you go through your Autodesk Account, Products and Services > Custom Installs (if that is available to you), you should have the ability to specify content packs on the 1 Add products page, under Customizations.
David Koch
Blog | LinkedIn
