第 1 条消息(共 5 条)
Shadow on ground doesn't apperar in render
不适用
03-04-2017
07:38 AM
I recently upgraded from Architecture 2015 to 2017. I'm working on a sun study. In model space the shadows are visible, but when I render the model, the shadows on ground won't appear. The same file used to work fine in 2015 on the same PC. I've tried rendering it online and there it turns out the way it's supposed to look like it is (low resolution image). I think there is nothing wrong with the model, but there must a command or setting in the software that needs to be changed. I've run out of ideas and need help to figure out what could be done.
Any advice is appreciated.
Patrick
Hi!
