FATAL ERROR during -transmit
Hello All,
This is the the Fatal Error I receive. "Unhandled Access Violation Reading 0x0000 Exception at 250162a0H"
It's due to objects being present from a newer version of AutoCAD however there are not.
1. I cannot seem to find anything even close to resembling an object enabler through my whole set up.
2. I change proxy graphics to 1 and try and e-transmit, still crashes.
3. It won't allow me to exporttoautocad because there are objects present from a newer file version.
4. Don't know what objects it could possibly be talking about.
Please advise. Thanks!
pendean
Community Legend
Community Legend
You seem to be in the middle of a topic, not starting out fresh so we can understand what you have for ACA versions, what OE you think you need, and if you first tried to fix all the files (and XREFs) are noted here https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
