saved alterations dont appear when re opening on another pc after sending
amber_newmanGLBKU
Message 1 of 13
amber_newmanGLBKU
Hi All new to autocad i have a student version (which i suspect may be the issue)
I am opening a .DWG file with a Model, layout, base and library layers
when i make changes and add items such as lighting etc to the model the changes appear on all layers and it looks fine.
I save the file with an updated file name
Send via email and tried usb to my laptop and log in to use free viewer to open it.
Despite spending hours trying all sorts the alterations don't appear, the laptop doesn't have the original file on it.
What am i doing wrong or is it a limitation because I'm using the student version, AutoCAD doesn't offer support to future users of their software, somewhat short sighted if i am to graduate eventually and choose something preferential to use...
Any advice would be greatly appreciated i need to be able to show progress my laptop is limited and so i use the desktop to do the work.
Thank you
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Student versions of AutoCADARCH have nothing to do with transporting your file on USB or through email.
What viewer is this? And why are you using a viewer if I may ask? The viewer may be the problem, nothing more.
Message 3 of 13
amber_newmanGLBKU
im using autocad free viewer so that if i send the file others who dont have autocad they could still see the updates when were doing group assignments, my laptop like many of my friends isnt exactly high end..
Message 4 of 13
amber_newmanGLBKU
i suspect now it might be a layer issue
So what i added so far was strip lighting when i open in viewer its not there on the layout layer but if i click 3d they appear.
Iv used the flatten tool to try and get everything on the same plane the lights and other components say 0 on z axis but they still dont appear
Im sure its me im still learning to use this so any advice greatly appreciated
Message 5 of 13
pendean
Community Legend
Community Legend
@amber_newmanGLBKU Any chance you can share your original unedited DWG file here?
Message 6 of 13
amber_newmanGLBKU
its part of a project i have to add a pile of features to this
thank you
Message 7 of 13
amber_newmanGLBKU
its definately to do with 3d and 2d the alterations show in 3d mode on viewer but not 2d but i cant seem to resolve the issue
Message 8 of 13
rwrightWMDSY
Stuff I would try:
1   on the laptop you sent it to, in model space do a zoom extents and make sure the missing objects aren't somewhere out in the stratosphere.
2   also on the laptop to a REGENALL and an AUDIT and turn on and unfreeze all layers.
3   If that doesn't work, do the same thing to the original file on your computer, save to a new name and resend it.
4   Before you send it, make sure the laptop doesn't have a copy of the original file on it.
Message 9 of 13
amber_newmanGLBKU
thanks
Message 10 of 13
pendean
Community Legend
Community Legend
This is your posted file (which is missing XREFs) in AutoCADARCHITECTURE
This is the same file in DWGTRUEVIEW (the free viewer)
They do look identical to me, what are you seeing?
If you see anything missing, it's might just probably the two missing XREFs you may have forgotten to share with your viewer laptop most likely?
I'm not sure what you mean about 3D vs 2D, there is nothing 3D in the file you shared here in AutoCADARCH, so no 3D in the free viewer either
Message 11 of 13
amber_newmanGLBKU
sorry i posted the original file
the one im trying to send has added halway strip lighting
when i send it i get the same as you saw minus the strip lights that i added
if you click 3d in viewer they appear there but not on the layout dwg
added below thanks so much for your time
Message 12 of 13
amber_newmanGLBKU
found it though i do not understand the significance
by selecting plot glyph and yes on display glyph when i re open in viewer the items are there
Thanks so much for taking the time to post if you know what the glypgh thing is about im keen to learn all i can with this software.
x
Message 13 of 13
pendean
Community Legend
Community Legend
Unless I am mistaken, you added these 7 and they look the same in both software over here, what do they look alike st your end?
