第 1 条消息(共 13 条)
不适用
09-14-2017
09:39 AM
i got most of my setting back from reset I was forced to do by autocad due to crashing when it would open, but I found one command ONLY my computer out of the 4 had so I'm assuming it was something custom.
I could type "RS" (room size) .. click where i wanted text. then corner on each size and it would give me that room size.
since reset that command does not work, any idea on how to get back ? or Maybe name of file it was in ? I do have zip file of my back up even though I can use it since it makes my Autocad crazy when I try and reinstall it.
Thank you again for all your help
Tim
已解决! 转到解答。
