Rest dynamic block
Rest dynamic block
marymAGTL5
Rest dynamic block
marymAGTL5
I am using AutoCAD Architecture 2022 at work. I use AutoCAD 2024 at home.
In AutoCAD you can "reset block" after you've used visibility or commands. Is there a way to do this in Architecture 2022?
R_Tweed
I'm using 2023 and "resetblock" is available from command prompt nut is not in the shortcut menu.  Are you wanting to add it to your shortcut menu? I've attached a clipping from autocad profile cui that can be transferred if your familiar with the cui (customize user interface) command.
marymAGTL5
thank you. I didn't realize I could type it in the command line. I'm going to add to the .pgp file, can't do much with the cuix as we are on Enterprise and the keeper of the file won't make those types of changes. Much appreciated
