Detailed Schedule of Statistical Hangers
Hello everyone
I encountered an issue in the project, described as follows: I created a Hanger and marked it in the view. Multiple view block tags can be customized, but I am unable to generate a material usage plan for this node because the component is referenced externally in the view. The generated schedule is applicable to all hangers, which is not my requirement. I only need the material plan for this node. How can I solve this problem, or is there any other way to meet my needs? Another point to note is that generating a profile format is not feasible, as tags cannot select objects. Currently, I am using the XCLIP command to crop the view for labeling, so I am unable to generate a material schedule that only targets that node.
I will attach the attached image.
Looking forward to a reply from a kind-hearted person
