Schedule question about headers (modified)
amapostolou
amapostolou
Is it possible to remove the line between the headers?
Better asked, is there a way to enter multi-line text in a header so the column isn't extra wide?
Per the screenshot, remove the line between MATS PER & SHEET, and SHEETS & USED.
I used a header to achieve the multi-line text.
Anthony
David_W_Koch
Set a fixed column width.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
amapostolou
PERFECT!!  Too simple.
Thank you!
David_W_Koch
Or turn off the Header Row Lines component.
David Koch
Blog | LinkedIn
amapostolou
That's good to know.  Tried it looks weird.  Good suggestion tho.
