Resources for learning AutoCAD Architecture
My work is currently using Autodesk Autocad Architecture 2015.  I haven't worked on Autocad for over 10 yrs and need to get current quickly.  I tried working with it and it is like starting over.  Does anyone know a really good book for the Autocad Architecture 2015 that takes you step by step from beginner on, that is easy to understand, that I could order.   I was first told it was 2019 and had ordered a book for that but then was told it was 2015 and want to send the book I have back and get the correct one for 2015 to make it easy since I have a short time to totally relearn the program.  Thank you.
@Anonymous for clarity kevin.palmer edited the original subject: AutoCad 2015 question
pendean
Community Legend
Community Legend
Autodesk AutoCAD Architecture 2015 Fundamentals is sold at amazon.com and is a good starter book.
Here is a good walk through of a project using the software for when you move beyond the book above http://www3.wayne.kyschools.us/userfiles/290/Classes/17793/SamplePDF-ACA2015Imperial.pdf
Kevin.Palmer
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
In addition to @pendean's post, here is a link to another thread, Your favorite Learning Resources for Autocad Architecture, that is full of great resources to help you brush up on ACA.
I hope this helps!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
