Remove regen from matchprop command
martin.horne98QZ6
martin.horne98QZ6
Evening
I am using Architecture 2021, I've noticed that MATCHPROP adds a REGEN at the end of the command, is there a way to disable this? I only ask because if the MATCHPROP command is repeated (right click if you have it set that way) it just repeats the REGEN command.
I swear this has never been the case in previous versions I have used but, I could be very wrong..
Many thanks
pendean
Community Legend
Community Legend
Nope.
martin.horne98QZ6
@pendeanthanks. Has it always been like that?
pendean
Community Legend
Community Legend
Most likely your PC/Video card and 2021 do not get along: it is only noticeable in AutoCAD (all versions) on struggling PCs or exceptionally large/dense objects from what I've seen myself.
I do not see it at all in 2021 on my desktop "workstation" PC: tested it on my MSSurfacePro laptop with one of my other files as well before I replied and it is not noticeable there either.
David_W_Koch
@martin.horne98QZ6 wrote:
Evening
Many thanks
Interesting.  I do not have AutoCAD Architecture 2021 installed on the computer I am using right now, but I will try it out on my next opportunity.  In AutoCAD Architecture 2020, it may be doing a regen after I use MATCHPROP, but if I right click to repeat the last command, I get MATCHPROP, not REGEN.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
David_W_Koch
I am not experiencing this in 2021, either.  Right click repeats MATCHPROP for me.
I am running AutoCAD Architecture 2021.0.1 (8.3.61.0) on AutoCAD 2021.1 (R.118.0.0).
David Koch
Blog | LinkedIn
martin.horne98QZ6
Thank you for checking @David_W_Koch
I have found the problem is the latest version of the third party add on software we use with Architecture. It seems to be the source of many anomalies that I am unfairly attributing to AutoCAD Architecture!
