invalid insertion point xref
Message 1 of 12
I am trying to insert an x-ref file to a new drawing, but I get an error message I have never had before "invalid insertion point". So it won´t insert at all.
I've tried different path alternatives, change the value of the insertion point etc, but does not help. I can open the file itself without trouble. I do need the xref to arrive at its own coordinates, the rest of the drawing will depend on it. I've purged both new document and x-ref. Does not help.
After googling I cannot find the same issue, most seem to have got the x-ref into the drawing before they get an error-message.
I'm importing in modelspace, and do as I always do. So fairly confused now.
Appreciate any advice 🙂
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
To work with Absolute Coordinates (#) Dynamic input (F12) must be on.
Or is the XREF from a newer ACA version (2018 and newer) and you are using an older version of ACA (2017 and older)?
Message 3 of 12
dbroad
Post a screencast or at least a command log.  Is the problem just with attaching a particular drawing?
Quote:
"most seem to have got the x-ref into the drawing".
Are others attaching the same DWG file?
Are you inserting, importing, or xattaching?
Architect, Registered NC, VA, SC, & GA.
Message 4 of 12
When I tried to find others experiencing the same problem, I did not find anyone. Those who had insertion point  issues are managing to get their files into the drawing before a message arrive whereas I never get that far even. I'm trying to attach an x-ref. Now I got another error message too. attaching that one as well even though I got rid of it again.
Thank you for your time!
Message 5 of 12
The version I use is ACA 20, so that should not be the problem.
I am not sure what you mean by F12 needing to be on? I pressed the F12 button and tried to import the file after, but same result.
Thanks for your time!
Message 6 of 12
dbroad
When you get the error pop-up, move it so it isn't blocking the underlying dialog before using print screen. Otherwise, we can't see the setting that might be rejected.
Message 7 of 12
pendean
Community Legend
Community Legend
So the problem is limited to this one top file then? it alone will not accept these XREFs but any other file, including a new file you create, will accept these same XREFs?
Have you tried to ensure none of your files have issues? RECOVER command on each and every one is a good place to start.
BTW, are you mixing DWG files with various scales? This is an unusual error message:
Message 8 of 12
Message 9 of 12
dbroad
It looks like you entered 1,00 rather than 1.00 for the x-scale.  That doesn't work unless you are using a localization that uses the comma for a decimal point. Your other decimal points look like periods.
Message 10 of 12
dbroad
Thanks.  Once I blew it up, I have the same comments. You are using commas for decimal points in some locations. Use periods instead.
https://docs.microsoft.com/en-us/globalization/locale/number-formatting
Message 11 of 12
I have until today not had a problem. But now when I try to attach other files as x-ref into a drawing, the same messge appear (just tried that), not just this file into the new drawing.
I will try the rocovery command!
Yes, we usually use various scales. The architects draw in mm while we who work with the exteriors work in m.
Message 12 of 12
Thank you!
I will watch out for that 🙂
Today it worked, I didn´t change any settings, but probably it was the comma/period difference. I appreciate it a lot!
