Project Browser and Project Navigator Missing from Quick Access Toolbar list
tevansERD
tevansERD
The Project Browser and Project Navigator options are missing from the Quick Access toolbar drop down list. I have the ACA.cuix loaded. Any ideas? I am running ACA 2018
Thank you in advance
Victoria.Studley
Hi @tevansERD,
That's odd - I'm sorry to hear they're missing from your QAT.
Are you in the default Architecture workspace, or have you created a custom workspace or transferred one of the core AutoCAD workspaces (Drafting & Annotation, 3D Modeling, etc.)?
Did they suddenly disappear?
Did you make any changes around the time they disappeared?
Do the Project Browser and Project Navigator open for you if you use their commands to open them?
Can you see them in the CUI Editor, nested under the Quick Access Toolbar section?
I'd recommend launching the program into one of the default Architecture profiles (US Imperial, US Metric, or Global), and testing the default Architecture workspace to see if the icons show up there. If they do, then you should be able to use the Transfer tab in the CUI to transfer the icons from the QAT in the default workspace to your custom workspace.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
That is odd. If everything else is ok you can add any ribbon tool to the QAT, just right click on the ribbon icon and "Add to Quick Access Toolbar"
Victoria.Studley
Hi @tevansERD,
I'm just checking in again to see if you need more help with this. Did the suggestions that @Anonymous and I provided help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
