Plot Delay
ACA 2016
So when I type 'PLOT' or hit CTRL+P, there is a long delay before I see the plot dialog box appear. It is usually between 25-45 seconds. It didn't used to do this.
It should be noted that we got rid of an old plotter long ago, but its default .PC3 file was always appearing as the default plotter, and then we'd select a different one whether actual plotter or PDF or whatever. So I went to that directory and deleted the old .PC3 file and in the OPTIONS dialog box set the default plotter to what we use most. That's when the delay started happening. I've tried several different default plotters and experience no difference.
Thoughts?
Scott
