Page Setup Manager
Page Setup Manager
Page Setup Manager
I have multiple sheet tabs in a drawing that I need to change the Plot Style Table (pen assignments). Is there a way to modify all of the sheet tabs globally or all at once as opposed to going to each individual sheet tab, right clicking, then selecting Page Setup Manager to modify this? We frequently get drawings done out of our office that have not been set-up according to our .CTB for pen assignments and page setup.
Thank you
dbroad
Add a page setup (using the new button in pagesetup) and then assign that setup to all of your layouts in the drawing.  You can also import page setups from a standard file and then assign them.
Architect, Registered NC, VA, SC, & GA.
kadmonkee
select one layout tab enter the page setup manager and change the settings (CTB) to what you need.
if all layout tabs are using the same page set up then they will all update to match your changes.
otherwise you will need to update each layout tab.
if you create a template file which can store all necessary page setups you can use the import function as mentioned in an earlier reply.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
