Only the Express Tools menu is showing in AutoCAD Architecture
carlos.h.silva
Message 1 of 18
carlos.h.silva
Good morning everyone, I'm getting a little desperate because I only do this routine every 5 years or more and I end up forgetting how it's done. When loading my menu bar only the Express menu appears, all the others are gone, File, Edit, Modify, Tools… I've been here for a while and I can't find the solution. Anyone on that side available to help?
thanks!
@carlos.h.silva Topic Title has been edited by the Community Manager for easier findability.
Replies (17)
Message 2 of 18
pendean
Community Legend
Community Legend
There have not been any of those menu pulldowns in AutoCADARCH for many versions now: you are thinking of plain AutoCAD perhaps, the profile (and separate CUIx menu) you are NOT running at the moment in AutoCADARCH.
Message 3 of 18
carlos.h.silva
thank you so much for your help!
And what is the solution?
Message 4 of 18
pendean
Community Legend
Community Legend
Last sentence in my last reply: if you did not understand it, explore here https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/sfdcarticles/sfdcarti...
HTH
Message 5 of 18
DesignHouseAD
Observer
Observer
Did you get to solve this?
The CUI didn't work for me
Message 6 of 18
David_W_Koch
@DesignHouseAD
Welcome to the community!
Are you using AutoCAD Architecture or just vanilla AutoCAD?  What version?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 7 of 18
DesignHouseAD
Observer
Observer
Autocad Architecture 2024
Message 8 of 18
pendean
Community Legend
Community Legend
@DesignHouseAD wrote:
...The CUI didn't work for me
What exactly did not work for you my friend? Read this, you have to perform a "transfer" if that was not as far as you got to
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-add-command...
Message 9 of 18
David_W_Koch
@DesignHouseAD
ACA.cuix is the main customization file that ships with AutoCAD Architecture.  There have not been any menu bar pull-down menus in it since ACA went fully to the ribbon.  If you install the Express Tools, its CUIX file has one pull-down menu, so if you set MENUBAR to 1 to turn on the menu bar, you will have the Express pull-down menu.  Third-party add-ins may also have a pull-down menu.
If you followed the instructions in the article to which @pendean linked and transferred the Menus from the ACAD.cuix file to the ACA.cuix file, then they should be available.  Perhaps they were added to ACA.cuix, but not added to your Workspace?  I just did a quick test in ACA 2023, and transferring the Menus from ACAD.cuix to ACA.cuix added them to the Architecture workspace, which is the only workspace I had.
Double-check that MENUBAR is set to 1.  The menu bar will not display if it is set to 0.
David Koch
Blog | LinkedIn
Message 10 of 18
DesignHouseAD
Observer
Observer
Thank you for your email.
I understand. It makes sense,
Message 11 of 18
DesignHouseAD
Observer
Observer
The menu is empty to transfer (there is no pull-down from the Menus)...I
understood now that the menu was a thing of the past...and only the Express
tool comes at the bar...?
[image: image.png]
Message 12 of 18
pendean
Community Legend
Community Legend
@DesignHouseAD AutoCADARCHITECTURE has not had a pulldown menu in quite a few versions now. What tools are you hoping to find in a pulldown exactly?
Message 13 of 18
rwrightWMDSY
Do mean the main toolbar across the top of the screen?  Right click the empty gray area to the right and a pull down menu will appear.  Click on DISPLAY TABS and you'll see a list of tool palettes you can display.
Message 14 of 18
DesignHouseAD
Observer
Observer
You are very kind, thank you for your effort. There is no menu to display.
I have use Autocad since Autocad 12..I understand what you mean, it is just
there is no menu when you pick the "+" symbol that displays...It is ok. I
know how to work without it...I just wanted to have it.
Thank you!!!
Message 15 of 18
rwrightWMDSY
I keep thinking this is just a matter of a system variable.  Have you tried just typing RIBBON in the command line?
Message 16 of 18
tintur85
Community Visitor
Community Visitor
Go to OPTIONS> PROFILES > CHANGE to AUTOCAD US or any another > Click RESET. Now go back and add MENUBAR from the drop-down Quick Access Toolbar.
Message 17 of 18
jhedhy
Community Visitor
Community Visitor
same problem on mine
any help pls
Message 18 of 18
pendean
Community Legend
Community Legend
@jhedhy The old-school menu bars (MENUBAR is the command name too) are non-existent in ARCH versions of AutoCAD (the topic of this post that you did a "me-too" reply on).
Are you sure that's your actual issue? They have not been around in a long time. Do you need to switch profiles to get plain AutoCAD and those menus to appear?
