Modify stairs path circle and arrow
gsucci
gsucci
see screen capture.
What dimension styles controls the huge circle at the beginning and end of the stairs path?
"Stairs_I" and "AEC_Leader_Dot_I" do not work.
Where is this documented?
thank you
Victoria.Studley
Hi @gsucci,
This dot is controlled by whichever dimension style your stair object is using. You can change the symbol as follows:
  • Enter the DIMSTY command.
  • Choose the dimension style that your stair references and choose Modify...
  • On the Symbols and Arrows tab, adjust the Arrowheads > First setting to use whichever symbol you'd like to use.
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
gsucci
Thank you Victoria,
now, how do you tell what dim style is my stairs using?
In its properties I cannot see any dimension styles specified.
Thank you
Gio
David_W_Koch
It is not a property of a specific stair (unless you applied an object-level display override), but is a display setting.
  1. Select your Stair, right click and choose Edit Object Display from the context menu.
  2. In the Object Display dialog, choose the Display Properties tab, if it is not already current.
  3. Make note of the Display Representation(s) listed in bold (active in the current display), and the associated Display Property source.  Since we are talking plan views, based on your image, you are likely using the Top View direction, and one of the "Plan" Display Representations is active.  In my sample file, the Plan Display Representation is the only active one, and the source is Drawing Default.  Assuming that is the case for you, and you want to have any changes apply to all Stairs without a style-level or object-level display override, select the Edit Display Properties button in the upper right corner.  Do NOT select the toggle in the Object Override column, unless you only want to change the settings for this stair, and you are willing to place an object override to achieve those results.
  4. In the Display Properties dialog, choose the Other tab.  In the Arrow area at the bottom, set the desired Dim Style.2018-07-15_ACA2018_Stair_EditObjectDisplay_PlanDRProperties_OtherTab_ArrowDimStyle.png
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
