Keynote value to property set definition
is there any way to get the keynotevalue in a style to a property set?keynote.PNG
David_W_Koch
There is not an Automatic property for the Keynote value.  Perhaps someone more familiar with the details of the AutoCAD Architecture object model than I am could figure out a Formula property that would retrieve that information.
Unless you have a large number of styles/definitions to which this would have to be added - or if this is something that changes frequently in your workflow, I would be tempted to create a style-based Property Set and add a Manual text property and manually type in the Keynote value.  I realize that will not update automatically if the Keynote value is changed.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Victoria.Studley
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the information that @David_W_Koch provided answer your question?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
