Mocoro unknown command
kjskoog
kjskoog
All my express tools work except Mocoro. Either using the ribbon or typing in the command I get "Unknown command "MOCORO"". Is there a way to get this back without unloading the Express menu and reloading?
Thanks in advance
Kory Skoog
CADD Technician
Kory Skoog
PM/BIM Manager
David_W_Koch
MOCORO works fine here in ACA 2014 and 2015.  What version are you using?
Do you have the command file for this?  Default installation area is
C:\program files\autodesk\autocad 20xx\express\mocoro.arx
where you would substitute the last two digits of the release year of the version you are using for xx.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
kjskoog
I am using ACA 2015. Mocoro.arx is located in C:\Program Files\Autodesk\AutoCAD 2015\Express. I do have the 2014 version of mocoro. Should I copy it into the 2015 folders?
Kory Skoog
CAD Technician
Kory Skoog
PM/BIM Manager
David_W_Koch
Kory Skoog
CAD Technician
If you have mocoro.arx in your 2015 Express folder, it should run (or is there a "not" missing from your first sentence)?  If it is missing, you could try copying the 2014 version.  On my computer, the two versions have different save dates and different file versions; I am not certain whether the older version will or will not run on the later release.  You could also try a repair installation or a re-installation of ACA 2015 (back up any customizations first), to see if that restores a 2015 version of mocoro.arx.
David Koch
Blog | LinkedIn
kjskoog
David;
I tried the repair and  rebooted but still does not work. Here is the message I get when going thru the ribbon menus.
Command: _.MOCORO Unknown command "MOCORO".
My next step is to remove express tools and then add it back in without doing a reinstall. What are your thoughts about that?
Kory Skoog
CAD Technician
Kory Skoog
PM/BIM Manager
kjskoog
Going through the Control Panel and adding Express Tools worked. Express Tools was shown as not installed even though it worked two days ago and all other Express Tools worked. Thank you.
Kory Skoog
CAD Technician
Kory Skoog
PM/BIM Manager
