LISP-routine to purge Style Manager?
jose.paredes9CU28
jose.paredes9CU28
When auditing drawings from construction-phase to built-phase I often need to Purge Style manager as drawings come with tons of unused styles, of all kinds of objects.
Is there any way to do this by a LISP-routine (that I can apply to dozens of drawings) instead of manually going into the manager and left-click on the file name, then go to purge? There must be a quicker way... thank you for your help guys
pendean
Community Legend
Community Legend
Reason you cannot purge is because they are in use: or do you wish to "purge" all that content as well?
>>>...When auditing drawings...<<<
Consider implementing and using CHECKSTANDARDS command with one of your template files to complete your files compliance/cleanup after you purged.
