Layer states changing automatically
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Melden
I am using ACA 2014, I have 23 different layer states in my template. On my drawings, I will create different viewports in paper space. Depending on what I want to show, I will go into the viewport and restore a layer state for that viewport. This state includes, in most instances, a change in the viewport color of a layer.
For example, I am drawing precast panels for a building. The layers are named P2.0_PANEL, P2.0_FINISH.... and so on. In the P2.0_ELEV layer state (elevation view), P2.0_panel has a color of yellow and is visible and in this layer state P2.0_FINISH is not visible. In P2.0_FINISH layer state, P2.0_PANEL is green and is visible and P2.0_FINISH is visible.
I will restore these states in the setup process when I am first laying out the viewports. Later in the design, I will be revising panel size or rebar type or whatever and then when I go back into the finish page (where P2.0_FINISH layer state was), I find that not all the viewports are correct. The colors have changed and the viewports are not displayed correctly. Somehow the viewports are not remembering their proper color representations. All the layers that are supposed to be visible are visible, but their colors are incorrect. Has anyone else worked with layerstates and had this problem? If so, have you figured out a solution?
AutoCAD user since 1993
AutoCAD LT 2023
