AutoCAD Architecture 2014 slow on Windows 10
DanMiddleton
DanMiddleton
I have purchased a new computer for the office:
ThinkStation P320 SFF, Core I7-7700
32GB DDR4 2400 DR x8 RAM
NVIDIA Quadro P1000 4GB Video card
Unfortunately, they can no longer install Windows 7.  So this speedy little computer has Windows 10 on it.  For some reason, running ACA 2014 it is the slowest computer in the company.  Changing layout tabs, takes sometimes up to one minute to do.  A regen takes an enormous amount of time.  If I open up the Windows Task Manager and look at CPU usage when I click on a different viewport, it barely moves.  So this is telling me that the CPU is not the culprit.  I realize that Windows 10 is not supported for ACA 2014, but does anyone out there have a solution that I could try to see if my speedy computer could live up to its' specs?
Dan Middleton
AutoCAD user since 1993
AutoCAD LT 2023
pendean
Community Legend
Community Legend
2014 (and 2015) versions of AutoCAD are not supported in Win10 https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-...
If you migrated a profile from the old PC to the new one, that may be your biggest problem: reset or reinstall ACA2014 to remove all of that.
Kill off all background running Autodesk programs, also turn off hardware acceleration too and see if that helps.
Try running ACA21014 in Win10's Compatibility Mode if running it "as administrator" does not help https://www.techadvisor.co.uk/how-to/windows/how-run-programs-as-administrator-in-windows-10-3632744...
Try the free tips here, and if they do not work, you might need to purchase their fix https://www.longbowsoftware.com
bruceVW9TY
We kept getting crashes in Windows 10, but the workaround for us was to run as administrator, and then go to the compatibility mode and select Windows Vista.  It now runs awesome, no crashes.
