Issue: application window overlaps second monitor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We thought this was a video card issue, (ran through everything graphics/display related) but its only with autocad that this overlapping window happens while the application is maximized. All other applications work fine.
What is happening, is when the application is active on the LEFT SIDE display, it overlaps onto the right side. When I select something on the RIGHT SIDE display it goes away. It doesn't matter what is on the right side display. It is about 1/8" wide. It happens all day every day, only with autocad. Working with Autocad Architecture 2020.
See attached image. that little black gap is the overlap of Autocad onto the second monitor.
What could be causing this.
