is there any method to create a Vertical Stair?
jtm2020hyo
Message 1 of 10
jtm2020hyo
I tried to create a vertical stair using Stair Styles but does not leave me set riser or treat at 0, then I tried to use the Column style but does not leave me to rotate vertically a profile, is there any method to create this object?
Replies (9)
Message 2 of 10
dbroad
Accomplish it by basic 3d modeling.  Create viewblocks from your model and then create the mvblock from the viewblocks.  You are drawing a ladder, not an architectural stair. There is no ladder object in ACA.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 10
odin
You were on the right path when looking at using Structural Member Styles but you could also have looked at using Curtain Wall Styles; these are great for ladders.  Because of the hoops, I recommend using a customized Member Style.  We, at ARCHIdigm.com are just wrapping up on our lasted kit for AutoCAD Architecture, "COLUMNS", and already had the fundamental components for your ladder type.  Hopefully, the attached file will provide you with the guidance needed to get the one you are seeking to create.
Odin Cary
principal, ARCHIdigm
Message 4 of 10
dbroad
Nice solution!
Message 5 of 10
jtm2020hyo
Wow, the best structural style I saw in my life
Message 6 of 10
jtm2020hyo
what you mean by " lasted kit for AutoCAD Architecture", is it a guide or course or book or library? could share the link?
Message 7 of 10
odin
“lasted” may have been a Freudian slip and/or concatenation of last and latest.  ARCHIdigm has been producing content for AutoCAD Architecture since release 1.0.  We were actually consultants for the original version created by Softdesk ages ago.
I don’t think I can post a URL but you can find us at archidigm.com
“COLUMNS” will be both a guide book and library of AutoCAD Architecture Member Styles for ACA 2017 and up.
Odin Cary
Principal, ARCHIdigm
Message 8 of 10
jtm2020hyo
I tried to insert more Structural Members and appears some errors, is there any method to fix it?
if you check the image the inserted block elements are rotated, I did not edit anything in your drawing.
this error just appears when I try to insert new Structural Members, but not when I copy your Style Directly.
PD: attached drawing.
Message 9 of 10
odin
At present I am unsure why the Blocks are "wandering" toward the Justification but I'll look into it further when time allows.
For now, keep the Justification as it was intended, "Baseline",  and all should prove to work fine; even as a Beam.
Sincerely,
Odin Cary
Message 10 of 10
faugustom
When exporting to AutoCAD, the "Ladder_Rung_Plan" block is being rotated to the original position.
There is a way to prevent this and maintain the visual visibility?
Thank's
