IFC import error
IFC import error
alysikov
IFC import error
alysikov
I have a problem importing from IFC. In AutoCAD Architecture 2020, I get an error on open an IFC.
 [DefaultDomain:     ]IMPORT STARTED: 12/2/2020 8:21:24 PM
 [DefaultDomain:Error]Autodesk.Aec.Ifc.Interop.OpColumn [IFCCOLUMN] (#2952791718) (GUID: 3aa1b001-db29-4483-8265-b250bd6c2f70):Main transaction for Beam import aborted
 [DefaultDomain:Error]Object reference not set to an instance of an object.
   at Autodesk.Aec.Ifc.Interop.OpStructuralMember.Import()
   at Autodesk.Aec.Ifc.Interop.OpColumn.Import()
 [DefaultDomain:Error]Autodesk.Aec.Ifc.Interop.OpColumn [IFCCOLUMN] (#2952791718) (GUID: 3aa1b001-db29-4483-8265-b250bd6c2f70):OpColumn:Object(#2952791718) Import Failed with system exception.
 [DefaultDomain:Error]Autodesk.Aec.Ifc.Interop.OpColumn [IFCCOLUMN] (#2952791811) (GUID: 15f8a452-447f-4478-bd52-a53e4ab2a7dc):Main transaction for Beam import aborted
 [DefaultDomain:Error]Autodesk.Aec.Ifc.Interop.OpColumn [IFCCOLUMN] (#2952791811) (GUID: 15f8a452-447f-4478-bd52-a53e4ab2a7dc):OpColumn:Object(#2952791811) Import Failed with system exception.
 [DefaultDomain:     ]
	Object Count:
	- AecsDbMember :	Total:  (3)
	  ** = Object classified as other IFC object.
 [DefaultDomain:     ]IMPORT ENDED: 12/2/2020 8:21:53 PM
Does anyone know what's wrong?
pendean
Community Legend
Community Legend
It appears your IFC contains objects ACA cannot translate: nothing to fix inside the program, perhaps another version of your IFC from another software might fix it.
