I should've downloaded your drawing before making a suggestion. This drawing is strange indeed. You have many unnecessary display representations for multi-view blocks. I count 10 unnecessary DR's including test1 and test2. All 220 MVblocks, with many duplicates are inserted at the same place in a non-WCS ucs, all rotated the same way.
The only thing that worked for me unfortunately was to delete the mvblocks and use the stylemanager to purge the mvblocks before using the diplaymanager to delete the DR's. Something is buggy IMO. It could be a structural weakness of ACA though.
Most of these MVblocks, perhaps all, were OOTB. In the future, I would recommend using the built-in DR's unless you have a very good reason for adding so many.
Architect, Registered NC, VA, SC, & GA.
