IFC-export Swing Door Operator
Hi!
Does anyone know what the correct IfcObjectClassification is for a swing door operator?
I have it in 3d and want to export it together with the door it belongs to. So I need to classify it correct regarding to the IFC-standard and I also need to set up a reference to the door (proberly with a property set definition)
Has anyone done this before?
brian_adams
Hello! I tried to export it having purposes to load it in Revit. And also I did a lot in property set definition to load exact values to REVIT. But the most of them didn't get through.But As i noteced very important to have precise map in a program where you want to import .
For example in my case i achived that windows ,windows assambly, walls, slab,openings and etc. Were successfully adopted..
structral elements only partly were recognased...problem with multy component wals and endcapes
brian_adams
In addition I have to say that display config also affect at result. Try to export it with "medium details"/"structural"/"diagnostic"( model orthogonal view) and import it into the target program
Victoria.Studley
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestions that @brian_adams provided work for you?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Hi, perhaps we are not talking about the same thing. My issue was how do I classify a swing door operator (se picture) regarding to the Ifcstandard when doing a Ifcexport. Now i export this as a IfcBuildingElementProxy so just wondering how others are doing :)?
