AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
How to stop Dimension extension lines from moving with xref (AutoCAD Arch 2017)
5 REPLIES 5
1142 Views, 5 Replies
I would like to move xrefs without the extension lines on dimensions moving across the screen to far ends.
5 REPLIES 5
Victoria.Studley
Victoria.Studley
Hi @Anonymous,
Could you record and post a quick Screencast video showing us exactly what's happening?
This will help us understand the workflow you're using, and should ultimately get you a quicker solution.
It would also be helpful if you could post a sample DWG file where the issue is occurring, so that we can test it.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Hi @Anonymous,
Victoria Studley
in reply to: Victoria.Studley
It would help to know - even if I dimension a newly created line, and move the line away, the extension lines move.  it does not matter if its an xref, or objects and lines, etc...
I can not make a video of it. sorry.
dbroad
dbroad
This behavior is as designed, if I understand you correctly.  If you're talking about plain AutoCAD dimensions, then you can set DIMASSOC to 1 from 2 or use DIMDISASSOCIATE to remove the association of the object from the dimension. I often use dimdisassociate because adding vertexes to polylines messes up associative dimensions and its not worth keeping them associative.
Architect, Registered NC, VA, SC, & GA.
in reply to: dbroad
Thank you! This is a great solution.
