I would like to move xrefs without the extension lines on dimensions moving across the screen to far ends.
Solved by dbroad. Go to Solution.
Hi @Anonymous,
Could you record and post a quick Screencast video showing us exactly what's happening?
This will help us understand the workflow you're using, and should ultimately get you a quicker solution.
It would also be helpful if you could post a sample DWG file where the issue is occurring, so that we can test it.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi @Anonymous,
It would help to know - even if I dimension a newly created line, and move the line away, the extension lines move. it does not matter if its an xref, or objects and lines, etc...
I can not make a video of it. sorry.
This behavior is as designed, if I understand you correctly. If you're talking about plain AutoCAD dimensions, then you can set DIMASSOC to 1 from 2 or use DIMDISASSOCIATE to remove the association of the object from the dimension. I often use dimdisassociate because adding vertexes to polylines messes up associative dimensions and its not worth keeping them associative.
Thank you! This is a great solution.
