How to embed and optimize a 3D model
Tell me how to embed and optimize a 3D model from an autodesk to a website? The site is small and it is very important that when adding it, the download speed does not drop. As far as I know, 3D models are heavy and need to be optimized correctly. Tell me how to do it right or leave a link to the materials
pendean
Community Legend
Community Legend
autodesk is the company name: which software are you using? AutoCAD is not a web tool, it doesn't embed 3D models onto websites.
HTH
dbroad
To share a DWF file via the web, this video demonstrates how to use AutoDesk 360 to share and embed a file.  DWF's however are not optimal for viewing however and have many faceting problems when displaying curves.
To share a DWG file via the web, consider this web page:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
Architect, Registered NC, VA, SC, & GA.
R_Tweed
I believe there is a thread about this in the Autocad forum. It sounds like you want to know how to make 3d models with the smallest file size possible.  This is done through modeling objects using the least number of faces, good layering,  and other methods that a used during the creation process.  Once the 3d portion is created then purging the dwg file is done which will further reduce the file size.  I'm not aware of an app or conversion software that will just do this for you.
